Soft pop from speaker when not in use - should I be concerned
Personally I would do the dedicated mains properly with a single 10mm cable to one socket, and use a mains block from there. A second socket means daisy chaining the cable from one to the other, so one of the sockets has to take two sets of cable which is an extremely tight fit and outside the design spec of any regular mains socket, albeit not totally impossible.
Thanks Chris.. that’s kinda where my head was going too.
I found this thread where several people suggested plugging power amp into the wall and other equipment into the mains block..
Exactly why i mention location when questions are asked, I deal with medical devices all over the world and the regulation are crazy varied. What we do in Spain isn’t allowed in the USA for example
Martin
One double socket would allow you to connect a mains block and use the other for a power amp if you wanted to try that arrangement.
Although it seems to be a popular concept with some people, that is a very distorted, and I believe wholly erroneous way of looking at hi-fi! Before anything else happens, the mains is transformed to whatever working voltage is desired, then it is rectified and smoothed, to create as pure DC as possible, as far as is achievable as different from the mains as it can get! Arguably it could be said that you are then modulating that DC, but it is absolutely not the mains that you are modulating. Any noise getting through the rectification and smoothing process modulates the DC and thus also the hi-fi output in some way, an undesirable effect, but that is fundamentally opposite from the music signal modulating tge nains!
