@CautiousLip
I’ll have a go at answering your question as I have reasonable experience of Solar PV, Solar hot water, a GSHP, a battery, diverter and EV complete with charger.
You need to look at everything your planning to do e.g. you mention changing your gas boiler and getting an EV and treat the whole thing holistically rather than piece meal.
Almost everybody worth listening to should start by telling you your first port of call is to look towards the insulation levels of your property. It’s a bit like Location, Location, Location in the property world, in this case it is insulation, insulation, insulation.
You don’t say how old your property is or whether you’ve pointed a thermal imaging camera at it in winter to see where heat is escaping be it through poorly insulated parts or as a result of unwanted air movement.
Solar PV - brilliant in summer and utterly useless in winter. My 12kW array produced 46kWh in the whole month of December…
Solar hot water - don’t bother
Solar diverter e.g. eddi or similar - definitely worthwhile. Combine with the likes of a Meixergy hot water tank system.
Battery - OK so the Tesla Powerwall 2 is well known and represents ‘reasonable’ value for money BUT is not very user friendly. I would recommend you look at other systems such as can use piggy bankable Pylontech battery systems.
Inverters - yes they can be noisy but then you wouldn’t have it your living room would you??? Depending on your roof orientation you mighty want to look at such as Solaredge c/w individual optimisers on each panel if spread across more then one roof.
How much solar PV? This depends on whether you want to do your bit for the planet and also on what your local DNO will allow. If you only have a single phase supply then, on paper you are limited to exporting 16A per phase however most DNO’s will allow you to exceed this provided there is some form of limitation device in play.
In my case the DNO allows me to export a maximum of 7.4kW or circa 30A.
Depending on how much battery you want to install you can charge these using solar or cheap rate electricity and then export it at peak times. Octopus’s Agile account allows this but isn’t perfect. More tariff’s will start to appear in time as well as more geared to EV owners.
Heat pump - most people are going to end up with air source jobs unless they have sufficient ground in which to lay ground loops. You presumably have a wet heating system currently presumably using radiators? Your heat pump is, ideally, going to be putting water out at 40°C with a 30°C return so the standard radiator is only outputting 20% of its rated output so you will need to upgrade radiators accordingly.
Such as Stelrad do triple panel jobs which are a direct replacement fit as the extra panel is just fitted to the non wall side so the wall fixings and pipe connections are in the same place.
Hot water - do not rely on the heat pump alone for this. Yes they can do it but off you are a family of four and its winter you simply can’t heat the house and the hot water at the same time. You need something like the Mixergy hot water tank system and integrate it with the heat pumps it is already able to work with.
That’s probably enough for now???
Feel free to message me if you need any more advice/ thoughts.
Richard
