All good things come to an end. My Heresy IIIs are on their way out. New house, room configurations, blah blah blah. They’re just not right in any of the new spaces. Slightly sad, but that’s the way it goes.
The real question is what’s next? Think I’ll get something new, but not quite sure what.
I really like the forward, lively sound of the Klipsch but need to tame some of the more raw elements that get in your face. I’d like something that gets close to that ‘live’ feel without the high-sensitivity / horn-loaded presentation in a medium sized room.
Electronics aside (will stay passive and will be some sort of Naim combo) and a budget of £1-2k does anything immediately spring to mind? Room and placement I’ll optimise for later - just need to do some design thinking over the next week or so.
I’d personally look at the smaller Zu , DeVore or Avantgarde, especially the new stuff from the latter with built in amps, although the latter takes you over budget and would require an amp sale.
One of the issues with having the Klipsch is that other people really don’t get the presence aspect of it, the liveness, soundstage or the excitement. They’ll reel off a whole pile of suggestions which aren’t really informed by anything other than “this goes well with Naim”.
Before getting my Zu I spent 3 years auditioining and one of the first things I learned was that high efficiency stuff steps out into the room and fills it far more often than “goes well with Naim”. The latter is a list of very good, competent and sometimes brilliant speakers which do lots of stuff really well but absolutely not what you want.
The ProAc mentioned above was instantly dismissed by me as, good as it was, it shrank what I was hearing from high efficiency stuff by about 50%. It sas like the music retreated.
My biggest takeaway is that you must listen using your ears. There are some top class ears on this community site, but they ain’t yours.
I listened to some speakers recommended by a lot of respectable ears on here with lots of years’ experience, and some speakers with great reviews behind them - and they just didn’t work for me.
You need to decide if you will buy new or pre-loved. If the latter I am not sure I can help. If the former, make a list of highly regarded speakers, then a separate list of dealers within an acceptable travelling distance
Then go listen.
Whittle the list down and then listen at home.
The answer will present itself.
I reckon Neat should be there, and Rega Aya (which are brilliant, but not it seems well loved here). But there we are - my ears, but it needs to be your ears.
I bought OePhi, but there are not many dealers and you won’t hear many recommending them, possibly as they are quite rare. My ears.
I listened them yesterday a few minutes at top the audio show in Milan, and were the only louspeakers i gad carried home, regardless of cost. Generally i’ve been pretty disgusted with most of the system there
I just got a pair of Neat Momentum SX5i’s and I love them. They have some midrange magic (voices) that is the most musical and engaging I have ever owned. They would fit your budget s/h (no longer in production). Looking at your profile it seems like the Klipsch were driven by a Pioneer from the late 60’s? Cool! But I see you also have a 202 / 200 combo which would be same ballpark as my SN1 I suppose. Happy hunting!
The difficulty with people recommending things is that speakers all sound so different, and what one person loves another may find unlistenable… In case you missed it another former Klipsch speaker user just changed for some JBLs (https://community.naimaudio.com/t/swap-moon-260d-qutest-dac-for-cd5si/45359)
To get decent speakers with that budget I’d only look secondhand, and FWIW. I’d suggest transmission line speakers such as from PMC, Kerr, or Castle did some, or even quite a bit older some TDL or IMF.
Guru’s can bring most stuff to life. I’ve got 10’s and 12’s. I’ve also got Neat Petites as a comparison and would say that the Guru’s are livelier, not a criticism of either speakers just a comment on their presentation style.
I see you are in Herts, if you wanted to hear them I’m in between St Albans and Watford, more than welcome.
Was a long and winding thread (didn’t really make sense to me) but saw at the end 70spete got those JBL 4309s. Interesting - might have a listen but think those are a little to close to the Heresy in presentation - but will give them their due attention. The PMC option is intriguing as well. Have never heard a pair, but they get a lot of airtime here
yes, will get there eventually with some soft furnishings and rugs, but the basic problem is that the main lounge is oblong in addition to differing widths from the doors. and the snug is exactly that - snug.
there’s just not enough air in between the sitting position and the front wall for speakers like these.
and they’re insanely loud. every room in our previous four-floor German bunker was sound-proof. this UK house is pretty shabbily built when it comes to stuff like that - thin walls, creaky floors, etc. no one here wants to listen to the Pretenders Live in NYC in their bedroom at midnight.
funny you say that - I may exactly do something of the like. was thinking about upgrading my LS50 Metas for R3s and then determining if I still need the KC62 in this new room
it may be an option if I set up the stereo to fire down the long walls
I’ve got both. I would say they are very different speakers even if from the same stable. Maybe I just don’t get on with the three way design of the R3 metas, they have a lot to admire but I don’t love them.
The ls50 have a cohesiveness to the sound that maybe down to their near single source design, I’ve got dual kc62’s on them and they are setup for projection out of the cabin into the garden.
