I need some advice. I was about to play some Pink Floyd but on lowering the arm on to the record, it slipped across the top and on further careful inspection I see that I seem to be missing the stylus! I do not understand why this has happened as it was playing beautifully yesterday and I haven’t touched it since. I believe they are glued on to the cantilever. Is that right?
Specs
Type: Moving Coil (MC) cartridge (based on a high-end Clearaudio design with custom Naim body/specs)
Stylus Shape: Microline
Cantilever Material: Boron
So the questions are:
have any other solstice/equinox owners experienced the same problem
And what can I do about it?
The tt is only a couple of years old ie i bought it a couple of years ago…. Hopefully it is still under warranty?
I will contact my hifi dealer tomorrow and see what they say
@Nicholas
Hi
The only consistent one I’d recommend is Goldring for retip and renovation.
I know there are others but too many permutations to mess with.
A Naim dealer might be able to offer a trade in replacement but not sure if they do it with this though.
I’d say Naim or dealer is the first port.
Good luck.
There are replacements. I very recently purchased a new Equinox cartridge from my dealer. As for randomly scooting across the record? I have no idea. Do you have the anti-skate set correctly? I set mine up by ear.
Hi Stephen. The reason it’s scooting across the record is I believe because the stylus is not anchoring the arm? As for the anti skate, I believe it is set correctly, as I have not adjusted it and it is set up properly for the equinox when it leaves the factory? I must admit I am a novice when it comes to the tt though.
I’ve found the Aro 2 to be a little temperamental and a rather sensitive soul. It’s a lovely design but if set up starts to drift, such as the tracking force, which can happen over time, from excessive up & down arm cueing and because of the very nature of the decoupling from the counter weight, then the arm may be prone to scoot and catch you out unexpectedly.
Keeping on top of things with the scales, periodically as a precautionary action, may alleviate such matters.
I would certainly press for your dealer to investigate and to fit you a new cartridge.
Wow!!! And people consider this even remotely acceptable for a turntable of such expense? If this is true, what a piece of junk. Not that I ever considered it, but damn, good thing I never did.
I replace my belt and re-oil the bearing once a year (even if not needed), and double-check VTF when the seasons change, but what you describe is just bonkers, and a complete non-issue for me. Sounds like Solstice has the flakey tonearm from hell.
If you use the arm gently with the arm lift, then it’s fine, never a problem. I was just merely pointing out what had happened to mine during regular use once, and I can be quite ham-fisted at times.
However, this maybe totally unrelated to Nicholas’s deck, just something to maybe be aware off, especially with the heavy counter weight, and if one is a little intoxicated.
As for the Solstice being piece of junk, that’s the last thing I’d call it, it’s a beautiful piece of engineering throughout …
My dealer now uses a Solstice in the main room as his source. He can’t sell it because there are none to sell. But he uses it anyway. Despite being a Linn and Rega dealer. Why? Well despite what JDP says the Solstice is no piece of junk at all … and it has the Naim sound man. It just boogies. A bit quirky yes … but you can’t argue with the sound.
I was responding to @Stephen_Tate description of the Aro2 and how finicky it is, not the OP. You think that kind of behavior from a tonearm is acceptible? I certainly don’t. When I setup my tonearm, nothing on it drifts, ever. If it did I would push for a warranty repair/replacement.
My comment was not directed towards the table as a whole. Just the tonearm.
I also think the Solstice outsmarted itself sometimes. The way the settings work on the tonearm seems to be trickier to set up and maintain vs for example the old string thing on Aro1. Also the small headshell was a bad blunder. Linn had already ran into this issue on the Ekos and needed to shorten the arm and lengthen the headshell to fix it on current Ekos’. Naim should have known better.
I would have thought that a stylus becoming unglued would be a warranty matter and that the episode would be of interest to the manufacturer to inform their own QC. Most likely, this was a 1 in 10000 happening and not indicative of a systemic problem.
Have a look for the diamond and display it as ‘an adventure at the high end’.
If you can find the stylus a retipper can glue it back on.
I had that with a Koetsu Rosewood and a retipper charged me $200 to glue the sylus back on and test it. I got the cartridge for nothing because it was damaged. The stylus had been pushed thru the top of the cantilever, but was still hanging there trapped by the glue. The retipper said it looks like it had almost no wear.
