Morning - my ultrarendu is configured as Roon endpoint currently with Innuos zen mini mk3 as roon core. If i want to use innuos own software to play and manage my library, what app to i need to download from Sonore and how do i configure it? there appear to be several but what the differences are is beyond me i afraid.
any help appreciated!
You just need to set the UR up as a UPnP renderer. Load up the MPD/DLNA renderer application and you should then be able to stream from the Innuos via the UR.
The manual is here if you’ve not seen it
excellent! probably the only one i have not loaded this morning! i assumed the sqeezebox ones so thanks James!
ok installed and ill give it a go later. do i need to tick compatability mode? is says for controllers that dont support OpenHome and disables streaming via Linn Kazzo? i assume leave unticked
Not sure about that one. I don’t have a UR in front of me anymore to play with
