Set up is ND555 with 555 DR PS, 552, 300DR and Kudos Titan 606. Recently upgraded to SL cabling. I was surprised and very impressed by the cabling upgrade. Can someone tell me about necessary positioning of the Sonus Fabers ? My room requires the speakers to be close to the wall
Do you mean that you consider to replace your kudos by sonus Faber’s?
They have to be far away from the wall as they have a rich and heavy balance. I would also suggest they need to be bi-amped.
YES. ANY FEEDBACK???
Thanks Devraj - that is very helpful
