The TQBII is a very good cable, and is what I use.
I bet, I will find a āApproved by the halibutā-sticker on the packaging.
Joking aside: So good to hear, @anon4489532, that you are happy with that cable and that you can recommend it.
That reassures and encourages me very much. Thanks ā¦
Iāve had TQB which I thought was nice coherent but a bit rolled off or sort of strangling.
Much prefer Witchhat Phantom on my SN2.
Phew. Iām like whaaaaa?
I guess someone has to mention NACA5 so it might as well be me. Itās likely to be what Naim used when developing the Atom. I tried it with my Atom and sonically it worked very well with my Neat Iotas. The only reason I didnāt stick with it is that itās stiff and awkward to use with wall- mounted speakers. Reasonably priced, too, especially second hand.
Roger
I have NACA5 on mine. No issues at all and sounds fine. I had the leads from my main system so though Iād giving it a try rather than spend money. Just as well as my wife was concerned that I was looking at another run of SL for the Atom!
Thanks for all of your recommendations. Witch Hat Phantom Cables are not easy to get in Germany as far as I know. The NACA5 sounds like a good recommendation beside the Tellurium Q Black II.
Sometimes I read that users recommend having a minimum cable length of 3.0/3.5 meters. I am assuming that this is only relevant for bigger and more complex systems than an Atom, isnāt it. I actually only need 2.0 meters between my Atom and the GURUs ā¦
Older Naim amps are more picky. The recommended lengths are minimum of 3.5 m NACA5, ideal 5-10, and max 20:
With the new amps you have more leeway. I use 5.5 m with a NAP 300DR, perfect for the farther speaker. As you can see in the pix in the other thread (link: Speaker cable for Supernait 3), I fold the cable to the closer speaker once. This, or the firecracker folding that Richard mentions in the FAQ, can work very well depending on scenario - again because you can bend the NACA into shape
Good to hear, @Suedkiez, that there is more leeway with newer amps. In my room the space is rather limited. There is only 1.60 meters between the speakers and the Atom is sitting in the middle. So the distance is very very short and the the space to place very long cables in a decent way is limited. So I would like to use only 2.0 maybe 2.5 meters. My current cables are 2.0 meters each.
Is the recommendation of 3.5 meters minimum mentioned in the linkes thread only for the NACA5?
The length results from the electrical specifications of the cable, as they are given for A5 in the linked FAQ. A different cable with different specs might require different lengths to have the same electric effect. (And some cables may be unsuitable)
The amps consider and use the cable as part of the circuit design, as Richard explains. However, itās the older amps that are picky about this. With the newer (and I am guessing esp. Uniti), it is not such a problem as long as you are not using ridiculous lengths of very unsuitable cables (typically litz type: āHigh capacitance &/or very low inductance cables are to be avoided at all costs and may result in damage to your amplifier.ā This still applies to Uniti.)
I.e., with 2 -2.5 meter NACA5 you should be fine on a Uniti
Also see
I seem to recall a forum thread about a Uniti (?) getting very hot which turned out to be caused by a litz type cable
Hi Suedkiez, I am back from dinner now
I am not sure that, with the new Naim black amps itās absolutely necessary to have minimum 3,5 m of speakers cables. It was true before.
However @Richard.Dane can confirm.
No you are right, itās not. But I said that!
Thanks, @frenchrooster, if I understood @Suedkiez correctly, he already said that newer amps like an Atom are little more flexible here ā¦
Personally, I would not use less than 3.5m of NACA5 with the current Naim power amps (the integrateds and all-in-ones may well be happier though). I felt the power amps also sound better with 5m or more per channel. With the minimum of 3.5m the sound was just a bit āedgyā whereas everything seemed to flow with much more ease with the longer lengths. FWIW, I use 10m of NACA5 per channel with my own NAP250DR.
Good to know. I have 2X 6m .
Oh, I am a little jealous now. With that or with the 10 meters of Richard I could build a Faraday cage in my room.
Great to hear that you can benefit from the whole potential here ā¦
The other thing that might be worth bearing in mind is that a less than 3.5m run of NACA5 would be something one would likely have to take to grave, as a (vast?) majority of Naim users may not even consider that.
Granted, itās not that expensive to begin with, but still.
You might find room e.g. behind some furniture, where you can do the firecracker fold like this:
Photo credit: Mike-B in an older thread.
As you can accommodate 2,5 meters, maybe this lets you add another meter. Also one long fold is an option like in my pic that I linked further up. Would only have to be 2 x 50 cm to take out one meter
The 2X 6m are for a good reason, my system is on the wall right and my speakers on the wall front. So I have nothing between my speakersā¦ it sounds better like that.
