Unlike the IOS version, there appears to be no ability to stop the app from applying alphabetical ordering. There is no A-Z option at the top of the screen so the order carefully applied by my upnp server is ignored. Can we have parity between the apps and have this function as i have sort tags and the ago won’t let me user them.
Philip
Seems to be a problem with a new update. Before I had the A-Z option, now it has gone. As I set it before to use the sort order of my upnp server it still does.
Now on my new phone I also cannot disable the alphabetical ordering. I hope it will be fixed in an new version.
Volker
