I wonder how to adjust the order of the webradio stations marked as favourites. Is there a way to customize the order? Currently running a NDX 2 and 2 Muso Qbs.
On the app, touch āEdit presetsā and then with a finger on the station & a with a slight āpushā to the left it can be placed where you want
Thanks, @Mike-B, this works for the Muso but not for the NDX 2. There simply is no āedit presetsā entry.
OK ā¦ sorry but I donāt know NDX2 that well
This function is missing from the new streamers, and a few others have raised the same point. Probably worth giving this feedback to Naim, as thet might be able to add it if they realise that people want it.
I sent an E-Mail to Naim-Support-Team requesting to integrate this āfeatureā in a future release.
Speaking to Naim at the recent Bristol show this is a work in progress item.
I hope they also do it for the new nd5 xs2
Two updates later: issue not solved
