What is the biggest cable the included naim speaker plugs can take?
I am thinking of making my own cables with the naim termination on the amp side and bare cable on the other.
NACA5 is 4 square mm cable and it’s a fairly tight fit in a Naim plug, so anything significantly thicker than that won’t fit.
