My Uniti 2 is paired with Usher Mini Dancer Ones. Although I am generally happy with the set up at lower volumes, the sound gets distorted at higher volumes. I think the ushers are a little difficult to drive. Should I get an additional Naim power amp, or should I replace the speakers with something else, such as Rega or Q-Acoustics? Any suggestions before x-mas would be greatly appreciated
You could add a nap200 but that is with the understanding that your speakers are performing optimally with the room. Easier to drive speakers might be the simpler solution, rega do gel with naim as do neats.
