Thanks for reply it seems to be the fridge at the back of the room is causing some problem with
tweeter so I have the speaker toe in a slight bit more now and the brightness is calmed down alot. Focal recommend the sopra to be angled towards listening position anyway.
Hey innocent!
I didn’t do any measurements but moved the speakers around to find what I think is best. I agree about the bass. Should be stereo image and higher frequencies. Perhaps the higher frequencies now work better with the bass making for a more Composed sounds.
