Are you a U or a V or an X ?
It depends.
Non U?
I am a V.
I identify as poly fluid, mostly V with a little touch of X.
Not sure what you mean, @Paul_C ā¦? And I would rather not guessā¦
Pls - can you explain your question betterā¦??
Iāll give you a clue. Most Kudos Titan owners are a U, some with a touch of V.
Seriously it is about how much are your speakers toed in.
Can I try toā¦ interpret this thenā¦?
U - meaning both speakers back to the wall, and parallel to each otherā¦
V - toed in - but not ācrossed overā
X - toed in - and ācrossed overā
Do I win a Mars Barā¦??
What suits best will depend on the speakers, and also on the room, the speaker positioning, and listening positionā¦
Mine are directed slightly behind the listening position (which is about 40% of the distance from front to back wall). So sitting just above base o& V, or above crossover point of X.
Youāre a winner.
On one of my systems I prefer to listen with my back in direction of the loudspeakers. What is the suggested character for that?
M
I reckon
Must be like being at the bar at a concertā¦thinking of the Hackney Empire, where the bar is at the back of, but still in, the auditorium!
V
My Focal Aria 926 are toed in with the crossing axis behind my earsā¦
X here.
Forum will not let me reply with just an āXā.
Surely never an X?
Mine are V but are focused a long way behind me rather than just the 300 mm or so that used to be recommended.
Thatās more of a U.
Bugger, youāre right. I didnāt read the descriptions correctly. The focal point is behind me.
So are parallel an H?
