Can anyone with Neat Ministra speakers suggest speaker stands
Custom Design UK manufacture the FS104 special edition ministra
I’ve had a pair they are very good
Deeper than the standard 104 to cater for ministra depth
Solidsteel SS6 have the right top dimensions and with three legs, they will never wobble.
Thank you for your recommendation, I will check them out
I like the solidsteel ones, but the top plate measurements are small
Try Dynaudio Stand 20 with standard plate? Can fill them with sand or similar for damping and weight stability. My Dynaudio Special 40s sit on mine and sound really good (yes, as recommended by Dynaudio I realise but they are generally very good, well made and finished off well). I also have Herbie’s gliders under the 4 spikes per stand to protect our beautiful oak floor. Absolutely essential (so my wife tells me)
Be sure to fill the central column about 2/3 rds fill with their inert filler. It works
Ministra are 17cm wide.
SS6 top plate are 16cm wide.
Looks like Neat uses Custom Design FS104 Signature in their video.
Chalshus - I had a pair of the Custom Design FS104 ministra ( special to handle the ministra), from memory they weren’t the signature but another version
I’m pretty sure it’s in their catalog of all models
I’ll look up invoice just to see what dealer called them
It is the depth of the Neats which are 29cm, And the Solidsteel base is 16cm deep
Toonfan
The custom design stands for the ministra ‘s are
FS 104 Signature XL Design
Top plate dimension is 160 x 260mm
Can look it up on their website
not to divert this thread, but a question on the margin - is there a ‘right’ height for stands? barring the ‘tweeter at ear level’ guidance?
610 mm I think from memory
It is easy to install a new and deeper top plate. It is just a MDF board.
Not on the custom design it’s not MDF - it’s steel
That will also depend on speaker design, some are designed to have the mid at ear level. But tweeter is the most common.
Stand height will depend on that. So speaker design, listener height & seating arrangement.
Thank you all for the info, I bought the FS104
I’m pretty sure Neat used these from Quadraspire when promoting their Ministra. I may also be wrong of course.
Yes correct Stephen they did when they first came out
Then reverted to the Custom Design
