The crossovers on the back of the ARC were a plug in module just remove to go active and add the extra electronics.
I did the same went to 42/snaps/110 with Monitor Audio speakers and as you say the rest is history.
I used mine with Nytech amplification and went active. The little box sat underneath the main amp and the crossover just unplugged from the back of the speakers. All very straightfoward.
The active upgrade was very worthwhile and worked well with my LP12 at the time.
Wow, I didn’t know you had ARC speakers too. I remember the extra Nytech box from my visits to Sound Advice in Loughborough. Very neat.
Yes, I had them with the matching stands made from black MDF. They looked very elegant on those stands, with a slight lean back.
They are still around, my best mans brother has them with a vintage Rega 3 and my Nytech amp (CA252). I think the active amp needs attention so they are run passive.
I wonder what the 050’s would sound like on the end of my system?
