Splash screen
Is it possible to remove Radio Player from the splash screen please? I don’t use it and it just gets in the way. many thanks
There is an option under Settings to disable it.
Indeed: go to settings → radio player to switch it off …
Many thanks. I hadn’t seen it because I was going into Settings after finding the device, not before it. All done now
