Dear forum friends, I was wondering if you could help me with some information: for about a month now, I haven’t been able to connect to Spotify using my ND5 XS (running firmware 4.9). Does anyone have a solution? Thanks as always!
What happens when you try to use it? Is the streamer visible in the Spotify app?
Yes, but it says that the Nd5xs no longer works with Spotify.
Where does it say that? As far as I’m aware, Spotify Connect is still supported although higher res formats are not on Naim’s older streamers.
It says so in the Spotify app when I go to search for all available playback devices.
Are you using an original ND5XS, or the newer ND5XS2?. I could be wrong, but connect might only work with the newer streamer.
I’m listening to Spotify now on my ND5XS fine. Are you trying to choose lossless quality for this device? Only supports up to 320bps.
No, unfortunately, the Spotify app tells me that my ND5 XS no longer works with any format.
Ok, I’m still on 4.8 firmware so I guess you need to contact Naim support.
Just had a thought! Check the Spotify input is enabled on the ND5XS. Obvious but you never know. ![]()
This might help (Or not!) ![]()
