SSD via USB
Hi, just got the 333 streamer, gret device. I have some CDs ripped to SSD (256g) that I try to connect via USB1 on the front, but the display says “No input signal”. The SSD light up, so there is some sort of connection, but it cannot be played. What am I moissing here?
Is your usb stick in exfat ?
The drive will not auto-play just by plugging it in.
Have you checked, if the media is shown via the USB and Server inputs inside the app?
THAT was the problem, now reformatted, re-copied, working. Thanks!
