I have a SuperUniti, and I’d like to stack a Hi-Cap and StageLine on top of it. I have a shelf that would fit this stack, with about an inch-and-a-quarter to spare.
Is it ok to stack the Hi-Cap and SuperUniti directly on top of one another? If not, any recommendations on isolation coasters or the like that would fit in that limited space?
It’s a compromise but if that’s what you need to do…
I would try and keep the Stageline away from the two mains powered components if you can as it’s more sensitive (given its role dealing with low levels signals from a cartridge) to magnetic fields from the transformers in the Hicap and SU.
