emrei
#1
After reading the many forum pages I am still confused, before it was sort of brain/brawl for sources combo
Is there a kind soul to let me know a a stacking order for
552
300
Cd555
Nd555
3 PS555
I have 2 large shelf, 2 base and 5 medium
After cleaning I am reorginazing all and not much head left
AJK
#2
To start this off…
Left stack suggestion would be as follows, top to bottom
Large shelf - 552
Large shelf - CD555
Med shelf - ND555
Base - 300 HU
552 should sound better on top and it all depends on whether you are happy with the CD555 under a large shelf.
Right stack would be power supplies of course. I would put the 552 PS on top and then make cabeling the priority for the other supplies.
How was it before?
And when you are putting this lot back together try and remember its a fatanstic problem to have.
emrei
#3
Thank you
It ended it up like this:)
system
closed
#4
