Hi-Line on the CDX2. Remaining power from a Musicline Powerigel. NAPSC off on the floor well away from both columns.
Thoughts?
These are on the right long wall as I look at my speakers. Powerigel and NAPSC are to the left of both columns effectively behind my right speaker. Np other options available. Sofa to the right of the above two columns. Table lamp is non-negotiable for both of us.
202 above CDX2 is practicable. Ditto 200 above HC2DR. I’ve heard about putting the pre above the CDP before and the power above the power supply (XPS2) but not the HC2DR. Are gains tangible? Will it make cabling any easier? I can’t quite envisage how it separates interconnects from power cables.
NAPSC already on the Powerigel thanks. Swapping the left and right columns may be an issue because of speaker cable lengths and the location of the Powerigel.
I certainly find a small improvement from putting the preamp on top rather that the source, and others here have said the same. Trial and error is the best way, I think. There are always compromises, and sometimes it’s down to what makes the most sense with cable dressing.
All the power supplies and power amps have their big transformers at the right hand side of their cases (as you look at them) so putting them in the right hand stack gets those bits further away from the delicate stuff.
No further responses so far. I’m wondering about switching the volume around as suggested but does that really separate the power cables and interconnects if the Powerigel still has to stay to the left of the left stack? I’m looking down the back of my system and struggling to visualise the gain.
