Hi,
Where can i buy a K board for my MC Stageline?
Am looking on the net but not easy to find
Thanks a lot
There are no swappable boards in a Stageline like there used to be on a Naim pre, like a NAC 102, for example. There is just a single board built with an N, S, or K spec loading, etc.
You would be better off looking for a used Stageline K spec unit rather than the board that goes inside.
The Stageline does not have interchangeable boards. You need to trade one version for another, although Naim service dept. can change an S to a K, but NOT from an S or K to an N, and vice versa - for a price!
Thank you Richard
Thank you Robinho
