HI. With the above can any one tell me if its OK to connect the Stage line into the unused power supply connector of the 555 PS (output 2)? Output 1 being used for my NAC N 272. Any disadvantages to this ? I am looking save a PS box? If so which cable is required to do so. Naim says you can use 555 PS for this but not how
The second 555 output is for a CD555, NDS or ND555 only. It cannot be used for a Stageline. You’ll need a Flatcap, Hicap or Supercap for that. Or a different, self powered phono stage.
AH, can a NAPSC be used and if so what lead is required.
See my third sentence above.
The NAPSC supplies 18V. You need a 24V supply which the other PSUs provide.
Thank you
I believe that you can also use the Naim iSupply, if you can actually find one on that well known auction site - quite rare though, and they go for around a hundred.
I use a Hicap on my “S”. it works.
