Stageline N
Hi there.
I have a stageline N with one 5 pin socket. My hi cap is connected to my 200 and 202 via sockets 3&4. Does that mean I need a 5-4 pin cable to connect aux2 in on my 200?
Many thanks
Lee
No, all you need to connect the Stageline to the powered AUX2 input of your NAC202 is a SNAIC 5. The Stageline would have come with a SNAIC 5 when new.
Thanks for your reply Richard😊
I have already tried that, but nothing coming through the speakers from the turntable. I have connected a Rega planar 3 to the phono inputs of the stage line
Check your socket assignment on the NAC202
Aux 2 in & pwr is the only socket the the cable from the stageline will plug into
Check how the AUX2 is assigned. It may be assigned to RCA Phono instead of the AUX2 powered socket.
Hi Richard
You were spot on!
All working now😊
Many thanks
Nothing wrong with a Stageline N.
We use ours on powered socket of 252 for very occasional use. Does the job.
Lots of threads on cartridge matching.
