Thanks Richard. So standard version .25 to .5mv?
I have a few .5mv so don’t want to overload.
Standard version 0.15mV to 0.5mV, perhaps up to 0.6mV, but I think if you want to use carts over 0.5mV then you’re better off with the “E” version which gives a little extra headroom at the expense of a little gain.
Much appreciated
Do you know if there are plans to update the Superline in the near future?
You can find a S/H Superline easily. The Supercap DR is the last stop. But the 552 is a key interim stop. I would have to try the Superline if vinyl is important to you. Then take it slow. Vinyl is a commitment best considered carefully in a digital world.
I listen 90% of vinyl. I don’t see any 2nd hand popping up?
No, but even if I did, I couldn’t say anything.
