I’m soon to be the owner of a Naim XS2 (2018 40th Anniversary version) and I’m looking to buy a Stageline for my Rega P3/Exact 2. From what I can see, the Stageline comes with a “standard interconnect”. The specifications for the Naim standard interconnect indicate that it does not carry power. Assuming that I’ve got this correct, my question is; what cable should I look to buy for the XS2/Stageline?
I’m very excited to finally be on this slippery slope.
Hi, the Stageline is supplied with a 5 pin Snaic which does carry both power and signal. Note that the pin layout is different to a standard interconnect, it uses a 240° DIN plug instead of 180° to ensure that the two different leads cannot be connected to the wrong sockets.
