When charging the volume via the app or knob I get a audible click through the speakers. I’ve never noticed this before in the few years I’ve had the Star.
Is there a setting to turn it off,
It seems to have started since I’ve reinstalled everything after having a carpet laid
Worth checking if you’ve knocked the ground switch. You’re profile doesn’t show what else you have connected, but I’d check it’s at the default (chassis) setting.
I only have the speakers connected plus my Subwoofer connected to the speaker o/p
Might well be that it’s always clicked as I usually change volume when playing something. It just as I was reinstalling and not playing anything I noticed the volume was up at 80. So needed to turn it down
