Kryptos
#1
Mostly coming here to commiserate with like minded folk as I’ve already contacted my dealer and waiting for the course of action.
While doing the weekly dusting of the equipment I saw a sliver of light coming from the top of my Star.
On closer inspection the top left corner of the display panel seems to have come loose.
Very gently pressing the corner shows that it indeed loose. Dunno how long it’s been there as I run it with the screen mostly off.
Not the high point of my weekend I can tell you.
Kryptos
#2
Have feedback and apparently it can be fixed by the dealer by tightening some screws.
Kryptos
#3
So the dealer came by and it was indeed one screw that needed adjustment.
Now back to undisturbed listening. And it is going to work hard for its money, that Star, as we are pretty much back into lockdown over here!!!
system
closed
#4
