after listening to the app for a few hours if i go to change input (internet radio to album on qobuz) it doesnt work and just keeps playing.
i have to turn off the streamer and back on and all is ok
any advice?
any advice?
ps auto stand by time is set to never
stay connected is ticked
Of course you don’t listen to the app - the app simply tells the streamer what to do. It sounds as though your wifi might be a bit dubious. If you kill the app by flicking it off the screen and then restarting it, hopefully things will spring to life without restarting the NDX2, which shouldn’t be necessary. It may we worth turning off the whole network, router, switch, streamer and then turning it on in that order, allowing sufficient time between each step. Try turning off stay connected, it shouldn’t be needed.
