Strange build
So on my SN2, I’ve noticed that the case rings like a bell. It’s as if
Naim left off any dampening. I’m just curious since the case of my Hcdr sounds damped
I use a SN2 and have not had the problem. Do you have it on a rack?
Yes. If I give the top a flick with a finger it rings. When it gets warmed up from cold the ring is reduced about 25% . But for sure the top isn’t dampened.
Don’t worry. A lot of Naim casework rings, particularly Olive stuff. Rather then retain and store energy, which is bad, it actually helps to get rid of it. There is a surprising tonal similarity between the ringing of Naim glass on a Fraim and the ringing of the casework.
Thanks, that does make sense.
