Hi!
Suddenly these stacks appeared under the text in the display on my nac 272 where it’s usually flac data, can anyone explain what this is ??
The graph shows the buffer level (as full). Perhaps you have accidentally used the remote to toggle through the various screen display options.
That could be the mistake! Which button on the remote control is it?
The one with an i on it.
Yes of course! Thanks for the help!
