When I open Tidal through the Naim app, the audio quality is displayed as only AAC 44.1kHz 96kb/s.
Is it possible to stream FLAC files from Tidal using the Naim app?
I’d love to listen to high-resolution tracks on Tidal, such as Norah Jones in 24-bit 192kHz FLAC. Is this possible through Tidal on the Naim app?
I know AirPlay 2 supports a maximum sample rate of 48kHz and a maximum bit depth of 24-bit, but I would prefer to stream via a wired connection rather than wirelessly to the NDX2.
Are you sure you are playing from the Naim app directly to the streamer as I would expect it to say FLAC rather than AAC regardless of the playback resolution?
