You could use Airplay via an Airport express and take the digital out into the DAC. A wireless N AE can be bought secondhand for beer money these days.
You could use the USB input of either the ND5XS or the NDAC. Alternatively I would use a WiFi connection in preference to Bluetooth, but this would require an Airport Express and an optical cable. A Chromecast Audio would be another option, although Iâm not sure that you wouldnât find a few compatibility issues.
If your ND5 is a later Bluetooth model, you can use that. Presumably you have it connected to the NDAC via SPDIF?
Thanks, amazingly simple: as Suzy said it works just fine using the USB input
I have an Apple TV (2nd gen) , could I use this for wireless connection as well ?
That is, the Apple TV is wired to Dac, and Ipad connected via Wifi to Apple TV ??
According to the user manual, the nDACâs USB ports do not accept âusbâ data streams from a PC, but they are iPod/iPad/iPhone enabled. I assume that it puts the iPad/Pod/Phone into âstorage modeâ
And it does work; I confirmed that this morning before I posted. Interestingly, I also discovered that by using Synologyâs âDS Audioâ app on the iPad, I could pull itunes music files from the Synology NAS, and play them through the nDAC.
The NDAC and old generation streamers were developed when iPods, and iPhones using iTunes, were still popular, and the USB inputs were designed to cater for that, and were Apple certified for such use, as well as being able to play from USB sticks. At that time, Naim chose not to go for AirPlay certification, which I believe they saw as too much of a compromise to their design, and not worth the hassle just to add a convenience feature to what was primarily a networked UPnP streamer. Times and priorities change, of course, and the current streamers use both AirPlay and Chromecast. The USB ports therefore no longer work with iOS devices, but have much improved functionality with connected USB drives.
Blow me, youâre right! Last time I tried this I just got a message saying unsupported device, so assumed it wouldnât work, but Iâve just tried it again, and it does now.
You can also route audio from an iOS device to an Apple TV. I still have the older non 4K one with an SPDIF output which I then connect to an Arcam AV amp and that works in the same way and could be setup like that as an optical input in to the nDAC.
Will try with Apple TV later, not sure if I have an optical cable for this.
And then I only need to find out how to direct the signal from the ipad to the Apple TV.
Listening to Patricia Barber, streamed from Spotify free, I must say that it sounds MUCH better than expected.
For quite some time I have been wanting to be able to send audio digitally from my iPad to the stereo. I never imagined I had the solution right at hand!
Just moved the spdif that connected a Sony cdplayer with the dac to the Apple TV.
And ⌠magic! I now have both options: wireless via Airplay or USB directly from ipad to dac.
Glad to see that it works so nicely! One of the strenghts of the old Naim DAC is its number of inputs: I have an Allo DigiOne Signature, an Oppo 203 player, a Sony TV and a Chromecast Audio connected to my Naim DAC.
If you are planning to try out Roon, Airplay, Tidal, Qobuz, etc, you could also consider front-ending the nDAC with a Chord 2go + 2yu sever + transport.
With 1TB micro SD cards at about 300$, this gives you a complete server + streamer system that can run on a subnetwork completely independent of your LAN!
What do you mean by ND5? ND5XS, ND5XS2 or something else? An ND5XS2 would give you more or less the same functionalities of the 2go + 2yu combination with the addition of an onboard DAC. The ND5XS does not support Airplay, Chromecast, Roon and Qobuz, as far as I know. I guess if you have an ND5XS (or ND5XS2), this is already connected to your nDAC via BNC-BNC, right?
