Current headphone system cd5x&flat cap xs/trilogy 931 amp/focal clear / audeze lcd 2. Very happy with this system for my jazz/chamber cds.
I want to add a nd5xs2 to this system (Qobuz a necessity) using the trilogy amp.
Can any one foresee problems with this route?
I have ripped nearly all my cds to a hard drive using my Uniti star (inadequate headphone amp) but then wish to keep the two systems separate.
N
Should be fine, there’s 2 inputs on the 931.
Looking forward to my ND5 XS2 arriving for a similar streaming system.
I’ve just added a Heed headphone amp of my NDX2, with that and the ND5 you can select the variable volume control and then use the Naim app to control the volume as well (just set the headphone amp at a suitable set volume), works a treat.
Thank you.
ND 5 has been on order for a while.
Andy at Signals hopes by the end of June.
N
