Hi nbpf,
After few tried, managed to get Kazoo play music from MinimServer, only problem is, it couldn’t play DSD format, although I can view and select the file, but it didn’t play.
Just to check, do you have experience play DSD with Kazoo?
Kwan
No but replay of DSD files has nothing to do with Kazoo which is just a control point. Perhaps check (ask on) http://forum.minimserver.com/showthread.php?tid=1901?
I thought the same, but just suspect some settings need to be done on Kazoo, because I can use Mconnect and Lumin to play DSD file, and I prefer Kazoo over the other two.
I did search on MinimServer forum and find no solution.
I will try to register to MinimServer forum.
Kwan
