Super lumina 5-Pin to -Pin Din
Hi all
Is there a specific source component end on this cable as with other Naim cables ?
The black collar end goes to amp and the light grey collar into source. That’s my understanding of how it should be implemented.
As stated above. They are quite difficult to see in poor light but in good light you should be able to see that one is a light grey (source end ) and the other is black / dark grey. It took me a while!
I read somewhere if the name Naim is visible it should read in the direction source = N
Even quicker way is to try it both ways!
Thanks to all for the help on this
