I ordered a set of 200mm spade-to-4mm SL Bi-Wire Links. As they are made of Super Lumina directional HP cables, I would expect them to be directional, hence my order specs as spade-to-4mm.
How should I know for sure the directions of theses links if none of the four shows a source ring or if the box doesn’t bear label or include documentation for that matter?
An all academic question probably that would call for an answer even if equally academic for the sake of my long gone academic mind. Would anyone of you had an idea besides the ever invitation to try all configurations?
No idea. Not sure how 4mm to 4mm would work as you can’t connect them. 4mm to spade would only apply if your main cables were spade terminations. You have spade to 4mm so, perhaps obviously, that’s the direction.
Super Lumina jumper leads! - boy they are an expensive item. I have Super Lumina full loom but the jumpers were a bridge too far. A blooming expensive bridge.
Yes I have learnt that life is not fair a long time ago but seems to me the only people buying the jumpers are those that have laid out a small fortune for the speaker cables only to find the jumpers are a totally unreasonable price.
Doing the math and nego led me to believe that they weren’t largely more expensive than their contenders at the Chord Co, Nordost and Vertere shops.
A justification of their price may be found in their absence of directionality after all.
And in those speakers there is an internal wire doing the same job as the SL jumper. Probably a piece of basic, thin and very cheap wire costing a few pence.
