Supercap Dr fuse - Canada
Hi, just wanna ask is below fuse correctly for use in Canada ?
Good for 252/supercap dr, 300 non-Dr & Uniticore.
Manufacturer|[Littelfuse Inc.]
Manufacturer Product Number|0235.300MXP| Description: FUSE GLASS 300MA 250VAC 5X20MM
its the correct naim preferred vendor (Littel) and physical size (5x20mm) but i suspect you will need a higher current rating than 300MA, the correct current rating should be shown on the back of each bit of kit. You should also select the “T” type fuses (slow blow).
So i just looked at the back of kit i have here in the uk. Presumably in Canada you are 120v,
so for 120V the various fuse ratings shown on the back are:
Core: 1 amp
Supercap: 5 amp
300PS: 6.3 amp
All are “T” slow-blow / Anti-surge type.
(anyone else reading this note fuse ratings at 240V are less)
Lovely mate
Have to learn more from your guys
Much appreciated
You can check the rear panel:
Yeah, but an amateur just wants to get it all right! If you could hook me up with the fuse serial number, size, and amps for each unit, that’d be awesome.
Appreciate you sticking with me on this!
