Supercap Question
Upon looking inside my Olive Supercap
I noticed 2 shorter (3/4 length) resevoir caps that say Epcos on them.
Should I replace them?
Discussion of modifications to Naim kit is not allowed on the forum.
If you think your Scap has been modified it would be best to contact Naim or Darran @ Class A and get it rectified.
@Richard.Dane
Yup, it would appear your Supercap has at some point been fitted with incorrect capacitors by someone. There may well be other issues that are not so obvious so I would strongly suggest you get the Naim service dept. or someone like Darran at Class A to take a look and rectify things for you.
