I now have the Stiletto singing nicely, with its Lyra Kleos feeding my Superline. The Superline has a Z-foil airplug – to my old ear, a small but real uplift. A 576R plug seemed to suit the Linn Krystal, but I am not sure that it’s right for the Kleos. I will try plug-juggling, but what loading does everyone else use?
Peter recommended 576R and 1NF with my Kleos SL when I had a Superline. He also said that you could remove the 1NF to get a little more high frequency output at the risk of it being more susceptible to RF.
Many thanks. I have done so much A/B comparison in the last couple of months that 'my ears are full, if you see what I mean, so I was not looking forward to another round of it.
The 576R sounds better to me in terms of tone than the other plugs I have to hand, but my 576 is a Z-foil and my 560 and 600s are not…
It sounds from all the above as if I can lave it alone, which is frankly a relief.
