Is it OK to change these whilst the unit is on or do i need to power down each time
I’ve changed them hot quite a lot with no ill effects. It’s only 0.2 ish mV even with a record playing.
many thanks , just thought i should check
Ok to change the loading when powered.
Just as a measure of caution, I would mute the pre and change the channel selected while unplugging/plugging…
Sensible but I forgot onetime and it made no nasty noises so I tend to forget more often than not.
