I am about to trial a Superline/Supercap DR for my Michell Gyrodec (with Orbe upgrades) which uses a Lyra Delos cartridge. Im keen to hear from anyone who may have a similar set up please. Looking for general feedback as well as specific guidance on settings used for Lyra Delos
Thanks in advance
I use the Z Foil 400R from AV Options with my Lyra Kleos SL. When you complete the trial, I recommend you contact AV Options directly and get what you need from them. You will see the Phono Products section on the website and a link that says “Contact Us”. The Z Foil is a nice upgrade from the stock plugs.
I do not use the capacitance plugs at all.
