I just replaced the batteries in my remote that came with my 1st gen Supernait after many years. Now my remote doesn’t work. I can’t find how to program and I can’t tell exact model # of remote but looks like Looks like Narcom 4.
This is a Narcom 4. You can’t programme it as such. Are you sure the new batteries are really new? Have you pressed pre before using it to control the Supernait?
My Narcom 4 gave up the ghost a while ago and haven’t managed to fix it. I only use it to control my CD5XS which gets played once in a blue moon so have not chased up a replacement. Narcom 4s are thin on the ground but 5s are easier to find and I will control most products that the 4 does. I think this includes SN1, but you should check this out first.
