Does anyone know how to adjust gain on a Supernait 2? I can’t find anything in the manual.
You can’t.
There is no gain adjustment (outside of the volume knob) but you can run it in AV-mode (in the manual) which allows the source/another input to regulate volume – taking care to not hook anything up in this mode which could do some damage to speaker et al.
Volume and gain are of course different, and in AV bypass you are still controlling the volume, not the gain.
As others have posted. Is there a problem you’re trying to solve? Different levels between different source components?
