Pay attention to how the cables run and avoid loops. Give it a few days to settle and ideally leave
it powered on all the time, when it’s not in use it’s not pulling much power anyway.
With the Hi-Line, once it’s connected each end pull it back out just a few mm till it gives some resistance to keep it free moving in the socket
The HiCap Arrived as I was finishing the last post.
I did think it would need a couple of days or so to bed in. Initial thoughts is that I’ve lost a little depth in terms of soundstage, maybe a dip in musicality but I’ll let it be for now to settle in.
I’ve pulled the Hi-Line plugs back 2-3mm now as well.
Probably obvious but make sure the HiCap is the first thing you switch on and the last thing you switch off. It’ll need a day or two to settle, on a SN2, I’d expect it to tighten up the bottom end and to open up the mid/upper mid soundstage a bit as well.
When I added a Hi-Cap DR to my SN1 I didn’t notice a loss on bottom end, but it got soo much tighter and faster and lost a load of boom that was annoying me.
Also it lifted the sound stage a good bit vocals seemed better placed and a bit more pronounced.
That’s just what I noticed initially, could have been other things that have got better over time.
It’s been running a couple of days now and both the Hi-Line and the Hi-Cap seem to be improving nicely. Tighter and Faster at the bottom end is probably a very good description as to what I’m hearing.
Between the Hi-Cap and Hi-Line, I’m very happy with my current setup. I’ll sort out a plinths next followed by power cables a little later I think.
