Quick follow up - I checked another unit today & it exhibited the same issue. I assume that it’s down to the floating phono input relay being next to the AV input relay. As you say, shorting plugs cures it.
Neil.
Neil.
Great news, thanks for doing that
Sounds like a design flaw Neil?
I would guess here that if you selected the phono input then it would be expected to have a turntable connected.
Yes, maybe so, but crosstalk shouldn’t be possible anyway, it indicates a deficient shielding if nothing else.
From what I gather shielding is no panacea. You should use it only where absolutely necessary or where there’s no alternative as it can otherwise adversely affect performance.
