I think you’re confusing the “function” select buttons pre/rec/cd/tun that determine what kind of device the remote is controlling, with the “input” select buttons, which pick an input source. On p16 of my SN3 manual, it says with the remote in pre mode, the inputs can be selected directly using the number keys, or stepped through with the ff/rew keys.
Exactly. With the remote in pre mode it’s a case of pressing the relevant number from 1 to 6, or cycling through the inputs with the >> or << buttons.
If I listen to something on the NDX2 (Qobuz/Roon) via the SN3 all is good. If I stop the music (via Roon), after a period the NDX2 goes “to sleep”, but AIUI the SN3 doesn’t.
At the risk of being dim, why then do I have to reselect the NDX2 on the SN3 if I come back to using the NDX2 later in the day (Qobuz/Roon)?
That has not been my experience. As long as I have not selected another input on the SN3 in the interim (e.g. cd or phono), as soon as I resume Roon playback with the NDX2 as the selected “target”, it wakes up on its own and plays as before. Never have to touch the SN3.
This is vey strange. I have just come to my system, and saw that the SN3 had “CD” lit; I used the SN3 remote to select “STREAM” (by pressing " pre "). At this stage the NDX was off.
I then selected a track via iPad / Roon and the SN3 reverted to “CD” and at the same time the NDX woke up & started playing - but no sound (obviously).
Pressing " pre " again on the remote and the sound came.
I am not normally a technophobe (far from it), but I have no idea of why this should happen!
