i now feel like i’m now in a fortunate position to go for a NDX 2 or a Supernait 3? Given my current system, what do you think my next move should be? My source is a ND5 XS 2 and my amplifier is a NAIT XS 2 with a HiCap DR into Neat Motive SX2 speakers. I only listen to digital only should i say and am not interested in vinyl, i sold it all years ago…
Thank you for any insight on this current dilemma of mine and hope you’re all keeping safe!
Not going to answer your question directly yet, but how is your cabling/power(mains)/rack etc? I’ve found a Hi-Line and better power cables for example are nice improvements that can be used later on down the road.
Hi marcusman, thank you for replying. I use a HiLine from from streamer to amplifier. NAC A5 cables also. Power-Lines are throughout. I’m after a real ‘meat & potatoes’ uplift. What do you reckon?
Sounds like you have all your bases covered! Source-first advocates would say the NDX2 but for me the weakest link is the pre-amp in the XS2. I’d be inclined to go for the SN3 first then NDX2. I’m normally Source-first as well but I consider the pre-amp as part of the source. In my opinion the ND5 XS 2 sounds as good as the previous generation NDX minus the XPS-DR of course. Tough choice regardless.
Yes, i’d be inclined to go for the SN3 first but i also think it’s the NAIT XS 2’s power amp side of things thst are the weak point, not it’s pre-amp section. Erm… The thing is i’m not interested in vinyl at all…a cutting and scratching DJ maybe, but not for me… NDX 2?
Lucky boy! I’d go for the amp… then no screen issues to fret about! If I went for the NDX2 I’d be thinking the amp is letting the source down , so the sn3 for me…
I use a HiFi Racks rack and will eventually purchase a Fraim Lite. But that’s just icing on the cake IMHO. A real bourbon, meat and two veg is what i’m after, hence a black box?
I’ve been very impressed with the SN2 with the ND5 XS2 and Hi-Line. Maybe someone who’s used a SN2 and SN3 will chip in offering insight but, maybe an SN2 with the additional funds going towards a future NDX2 purchase?!?!
I’ve owned all the Supernaits and both the ND5’s and currently have both the SN3 + NDX2.
I’d be inclined to get a Supernait 2 and look out for a used or ex demo NDX2. Both will give measurable improvements over what you have today.
I’d expect the greater gains will come when you go to the NDX2 ultimately. If you can, do both in one go. Having had the SN2 till quite recently I’d have no hesitation recommending one to anyone, especially those moving from a 5 Series or XS NAIT, I nearly bought one myself last week!
Lots of fun ahead and I expected you to head this way sooner than later…
Thank you for your suggestion here trickiedickie. That is certainly an option that i would not of thought through and at the same time makes a whole lot of other sense. Naim DACs certainly appear to be bargains on the used market and de-coupling my ND5 XS 2 in that way certainly sounds intriguing to me.
That and a Supernait 3 with a HiCap DR could turn out to be a fantastic set. Especially as i could probably purchase both units for the price of a new NDX 2!
I would say, SN2 or SN3 first, since your streamer is at least the latest tech.
I just received my SN2, and it’s a fair step up from the amp in my Superuniti. I’ve connected the SU pre out, to the SN2 main in, and even with just the amp section of the SN2, there’s quite an appreciable increase in SQ. I’m also saving for an NDX 2. Probably a power supply upgrade in my future as well.
