The Supernait 3 comes with an mm phono stage and was wondering how you connect an mc phono amp. Does it still plug into the phono socket ?
No, use one of the other line in connections. Phono in is only for an mm cartridge, or mc with a step up transformer. Don’t connect another phono stage to the phono input.
A powered MC phonostage will plug into the line level-in socket on the Naim. A passive step up transformer will plug into the phono-in socket.
I use a cinemag based step up transformer between my cart and the SN3 phono in and it sounds killer.
Which MC phono stage are you trying to connect?
If it’s a Naim Stageline or Superline then use the powered AUX2 socket on the Supernait.
Was considering a Rega phonoamp
Then you would just use one of the line level inputs.
Have you considerded a High Output Moving Coil - such as from Dynavector - which could connect directly to your SN3’s phono input…?
I will stick with my Rega Apheta, thanks.
