I have connected my NDX2 to my Supernait and am loving it. My problem is that when I set up the control so I can change the volume via the NDX2 the source change on the Supernait from Streamer To CD. All help gratefully received.
That’s because you need to select input 3, as in my example below. If you didn’t know it, you can rename the SN3’s inputs to make life that bit easier, and disable those you don’t need, to keep the app tidy and make switching sources via the NDX2 remote quicker.
